jmbuys
88
MA
Went to the pool to check the water level under the cover to see if I needed to top it before opening and it is LOW. It's probably 12 inches below the bottom skimmers and returns and it's below the light. It's level w/ the bottom of the 2nd step on the stairs. Don't remember even having the water near this low before opening.
-Snow/rain around here I would say has been about average over the winter/spring.
-Since it's well below the skimmers and returns and light, it's none of those things. It's probably not the bottom drain because then it would be even lower.... I assume?
-The liner is old and will need replacing soon, but it was ok at closing and I doubt any type of hole in the lining could have caused this amount of loss.
-Could it be the stairs (since it is exactly level w/ the bottom of the 2nd stair? Anything else? Not sure what else to consider.
Thanks!
