Went to diagnose a Laars Lite2 pool heater only to find the 120/240vac Conversion Plug resistor burnt. The heater is wired in 240 volts and this plug was in the blue side which is correct for the 240 set up. I'm wondering if I were to convert the heater to a 120 voltage setup can I then plug the conversion plug in the 115 V direction. Plug #s on the board are e237500 which then comes down to a new part # of Ro336900. So the question still remains if it'll work on the 115v side after I convert the heater to 120v.
Also, here is a picture of the wiring diagram for the transformer showing the 120v wiring but just to clarify, WHEN I wire it for the 120v configuration one leg gets a hot wire and the second wire I presume gets a neutral ??
Laars Vac Conversion Plug 115/230 | R0366900
