- Feb 21, 2024
- 16
- Plaster
- Jandy Truclear / Ei
New pool owner that has been reading as much as I can on TFP. I just got my recommended test kit and I am still a little nervous about whether or not I am doing it all right. If you click through to my logs, please realize that the first set are probably off because I wasn’t doing it all properly (i.e. not waiting until the colors stopped changing and subtracting 1, not doing CYA outside, etc.). Second set should be closer.
I have two big things I am trying to accomplish and they are:
Based on my recent test results, I plan to add the recommended Muriatic Acid (172 oz) and that should help my pH and TA. Is that something I am going to keep having to do to maintain the pH or will it stabilize once I get the rest of the pool balanced? I feel like I add Muriatic Acid quite a bit, constantly fighting a high pH.
Next, I want to add the stabilizer to get my CYA up. I will say that I have added a LOT of conditioner since May. I was previously using Leslie’s to test my pool water and purchasing the conditioners from them. I have also used the Clorox version I found at Walmart. Per Pool Math I would need to add another 30lbs of conditioner to get to a target level of 75. I have been pouring the granular form directly into the skimmers (I have 5 skimmers). Any recommendations on how best to add it? Do I have to dilute the granular form or can I add it directly to the skimmers. Is liquid better? I don’t want to get my CYA too high especially as we head into the Fall. Does the season really matter if my pool will be in direct sunlight most of the day? We are still in the 90s air temperature here, but the in pool temperature has been an average of 85 this month.
I will stop there for now. I feel like once I get the FC, CYA and pH right I can start worrying about CH and tackle my filter, SWG, and staining questions.
I will take any tips, product recommendations, links to other threads that you may have.
TIA!
- Trying to get the CYA high enough that I can maintain a good FC. I am running both my SWGs at 100% and still cannot maintain a good FC. I want to be able to throttle it down especially when it gets cooler in Texas.
- I want to be able to get rid of some of the organic staining on my plaster. I have read the best way to do that is just to increase the FC? It would ‘bleach’ these dirt stains?
TIA!
