- Dec 17, 2020
- 6
- Plaster
- Jandy Aquapure 1400
Moved from HERE
Hi, I have the same problem so I tried your test and It worked initially. So, I opened the intake valves and water rushed in as normal but after a minute or so the water stopped coming into the filter basket. I first noticed the same problem this morning. The pump came on at 9am but a few minutes later I could see that there was no water being pulled into the filter basket. Next steps? Thank youCL, I agree the lid gasket is a potential problem. When you opened it up to clean the pump basket, that might have been its last good seal. But let's go over a few things for you to check:
- Make sure the pool water level is high enough. It should be about 3/4 up the opening of the poolside skimmer(s).
- Also check to ensure nothing is plugging the skimmer opening (hole); also check the skimmer weir door/flap is not stuck closed.
- The three valves in front of the pump appear to all be open - good.
- Then do this test .... close the intake valve handles to the pump and fill the pump basket full of water and close the lid. Don't open the intake valves yet. Now the test - turn the pump on briefly while watching under the clear lid. Have someone help you if the power switch is away from the pump. Watch to see if the water gets sucked "IN" by the pump (to the filter) and empties the pump basket. Then turn off the pump quickly. That test will ensure the pump is "pulling" water.
After that test, if it was successful by pulling water out of the basket, refill the pump basket, open the intake valves, and try the pump again. Give it about one full minute to pull water from the pool.
Now if the test above did not pull water to empty the basket, let us know.
