I loaded up my pool with Boric acid a year ago and after that it tested 50 with the La Motte test strips. I tested it again today: still 50! I wondered how this could be since I assumed some minor degradation should occur. So I tested my tap water. Result=zero. I guess the strips work and there is very little degradation of Borate. As a side note, I also tested my CYA levels. 9 months ago they were in the 50 range. Now, less than 30. So I added 2 pounds with the sock method.
