I've been a TFP practitioner for the past 3 years and I have to tell you, our pool in south Florida couldn't have been better. But recently I moved Southern California and my new home has a 22,500 gallon pool with an automatic cover. Pump and DE filter appear fine, but today I got my new TFP test kit after leaving my old kit for the new owners, and I've got to tell you the numbers are scary, and I'm not sure where to start.
PH 7.5
CL- 16.5
CC- .5
TC- 17.0
Calcium 800
TA 130
CYA 100
The system has a auto chlorinator (pucks) which is going to have to go as I intend to use 10% Sodium Hypochlorite. I'm worried about the Calcium levels (the pool has scaling) and the chlorine/CYA levels. Using the Pool Calculator I'll need to drain 68% of the water to get them both down and I "think" I know what I have to do. But I'm looking for some experience/wisdom. Do I remove the scale first, drain the pool 70%, fill and start testing to get balance? What would you do?
PH 7.5
CL- 16.5
CC- .5
TC- 17.0
Calcium 800
TA 130
CYA 100
