duraleigh said:one step at a time. I think your CYA will be about 50 but let's see.
Ok, Thanks Dave. I appreciate your help.
TechJPC said:Sigh ... There are stains on the bottom of the pool now and I think a smidgen of mustard algae (I saw yellow dust when I brushed). About 2 weeks ago I had mustard algae and used Yellow-Out and had iron stains after that so I did a AA treatment and it worked beautifully. Pool looked good for a day or so.
Now with this monkey wrench thrown in, what is my plan of attack now ? I do not have any AA left ( I would have to order online again).
I was thinking of backwashing until I could no longer backwash (to remove algae/iron) and then drain pool 1/2 way and refill, etc and then attack the staining next week when my AA is here, or I could be totally off base
duraleigh said:Does your fill water come from a well? Do you have positive test results for iron in your water?
Ascorbic Acid (Vitamin C powder)UnderWaterVanya said:TechJPC said:Sigh ... There are stains on the bottom of the pool now and I think a smidgen of mustard algae (I saw yellow dust when I brushed). About 2 weeks ago I had mustard algae and used Yellow-Out and had iron stains after that so I did a AA treatment and it worked beautifully. Pool looked good for a day or so.
What is AA treatment?
duraleigh said:Joe, one of the tenants we teach is to not throw things in your pool if you are not sure of the outcome.
There is no reason for you to do an AA treatment unless you test positive for metals.
Stop using Yellow-out...it voraciously consumes chlorine.
Go back to the issues you need to address....
1. You have no FC....algae is on the way....ok, you put some bleach in the pool
2. Your CYA is too high and you should drain about 1/3 of your pool, refill, then 1/3 again, refill and test.
3. Your pH is too low. If you do not drain refill right away, you will need to bring your pH up to 7.0 or more.
Stop by a pool store tomorrow and test for metals.
If you have a puck, hold the puck on the current stains for a minute or two and tell us if it lightens the stain or not.
duraleigh said:OK. but if you look at the article, "The ABC's of Pool Water Chemistry" up in Pool School, you find that the very acceptable parameters for pH are 7.2 - 7.8. Since you are at 7.2, you are fine.
My point is the pool calculator will not fix the pool nor should you use it as a hard and fast set of dictates that you have to meet for each time you test. The calculator is merely a tool to help you get within the ranges of "normal".
Additionally, my experience teaches me (and you will soongain this experience) thatMOST pools will tend to rise in pH and almost never lower so my thinking would be to leave the pH right where it is and not adjust it unless it gets to 7.8 or higher.
Does that make sense.
How does your water look? Stains still the same?
duraleigh said:Yes, that's what I would do. Your numbers now all look pretty good. Let you FC drift on down into the 3-5ppm range but never let it get below 3ppm.
Monitor pH and chlorine using the K-1000 for a week or so and then let's see what the stains are doing. If they are lightening up a little, then just leave them alone and they will eventually go away. If they have stayed the same, we'll get a plan to get rid of them.
