Just opened
Water surface temp here at 9:30 am is 60 degrees. Sun is out and did the cya test twice. Both times it looks like high upper 30’s. So I’ll round up to 40. I will monitor today and test tonight.
Reactions: bmoreswim
It looks like you are on the right track, you passed your OCLT and your pool looks great so i would lean towards low CYA as the cause of rapid daytime FC loss. Since you just added more CYA I would monitor the daytime FC loss for a couple days and see if increasing the CYA helped. You should only be loosing 2-3 FC per day, but you will loose more FC at SLAM level than you will if you keep it in the target range for your CYA.
Reactions: bmoreswim and JW1
Tested tonight after sunset and my FC dropped to 4 after starting the day at 8. It was another bright sunny day, a lot pear tree flowers floating in the air, and a high temperature of 75. With my cya of 40, my PoolMath states my range of FC is 3 - 7. I targeted 7 tonight with my dosage of LC. I shall see what tomorrow testing results will be like. I’m learning a lot and I appreciate the support and guidance.
