I just got to the point where I thought my pool was ready a few days ago. I balanced the water to what I thought was good:
PH - 7.4
TA - 110
Salt - 3600
CYA - 90
FC - 0
I turned on my chlorinator and it's been slow to add chlorine, slower than in the past. I got 1 CC after 24 hours at 25% runtime on chlorinator so I bumped that to 75% yesterday and it's been less than 24 hours and I'm at a 5 now but I see green slimy stuff starting to grow on the pool liner near the walls at the bottom and up a bit near skimmer.
I believe I was too high on the CYA this year measuring over 100, so I drained the water down twice below skimmer and re-added fresh water which brought me to a 90 reading with my test kit before turning on the chlorinator.
I've never saw this green type of algae before in my pool and need some advice. Here are my current water readings:
FC - 5
CC - .5
PH - 7.7
TA - 120
CYA - 90
Salt - 3800
CH - 250
I've turned up my chlorinator to slam (120%) and I've ordered some polyquat 60 algecide which will take a few days to get here. Based on the water readings normally I'd try to put in some acid to lower the PH and TA. Should I do that now while trying to get more chlorine in the pool? I had some rain but not alot which could have impacted the PH/TA (happens usually during heavy rain).
I am worried about the initial CYA being too high and being a chlorine lock condition. I've never had this before and I'm unsure where to go.
Please help!
PH - 7.4
TA - 110
Salt - 3600
CYA - 90
FC - 0
FC - 5
CC - .5
PH - 7.7
TA - 120
CYA - 90
Salt - 3800
CH - 250
Please help!
