Just filled pool, already algae?
kazie
3
massachusetts
Im new here, though I have been on this site the past 3 years frantically trying to figure out what to do :/
I have an intex pool because I don’t have room or money for a big one though I wish I could. It’s a 1,700 gallon with the metal poles. I know it’s laughable to call it a pool compared to everyone here— but it’s where my kid talks to me and we can look up at the stars and pretend we aren’t in this city.
I had it up all winter but I drained it at the end of last summer. Obviously I had to drain it again before filling it because it got snow and rain . So I drained and then siphoned (can’t spell) what was left .
I filled it with my garden hose- city water- I put a Clorox puck in a floater and then the pump hasn’t been off except for when we’ve been in it.
I started with adding the alkalinity rise, got it to the right spot, then it rained a little bit and the chlorine and alkalinity were still good so in started added ph rise. I got the ph to the right level.
I didn’t add stabilizer because the puck — but yesterday it was sunny and the solar cover made the water warm, I tested the water and no chlorine showed so I put the floater on highest setting and went to buy stabilizer. I came back home and My levels were all good chlorine was back .
So last night I decided to add the algaecide because it says to add it to new water. I figured I’d add the stabilizer today.
I woke up at four am to check the pool and i move the solar cover and there’s like brownish(?) foam kinda that looks like it built up from the water jet into the pool . It wasn’t a ton of it but now I see it on the floor of the pool like it sunk.
But my water was pretty yesterday!?!?
I’m just so sad cause I went and bought new chemicals this year and I was thinking I’ll get it right this time and I already failed.
I don’t know what to do.
What is the film.
If it’s algae it happened so fast like three days and I’m trying to figure out what it is online and I’m afraid it’s an algae that I read is resistant to chlorine…
I have an intex filter pump and I don’t think I can even hook a Vac up to it??? I have one of those vacs that attaches to the garden hose.
Does anyone know what to do I feel like giving up because I’ve read so many things online over the years and i can’t ever get it right.
I was planning on adding the stabilizer today and then this week buying liquid chlorine without stabilizer . But I just saw that this morning and added some more algaecide instead of the stabilizer. Should I still add the stabilizer I mixed it in a bucket like it said to but now it’s sitting in my garage.
If anyone replies, thank you….Kazie
What is the film.
Hi and welcome,
If youve been around 3 years, maybe you know the questions to ask. How are you testing the water and are you following the TFP ABC’s?
Note: algaecide isnt necessary. What was the algaecide you added?
Hi and welcome,
I didn’t know see the link you added in the past, I’ve been on this site because id search on google and an answered question would come up. I didn’t know till now that i didn’t need algecide. I used Clorox “Algecide &clarifier”
Can you look at the pictures I’m attaching and tell me if u think this is algae? I don’t know if maybe it’s a reaction to the algaecide i added… also there’s a ring of it on my chlorine floater. I tried to take a picture of what it looks like on the skimmer net. There was a couple bubbles of it in the water too. But my water looks clear and when I look up algae in pool it always shows nasty looking water.
How are you testing the water?
Looks like suntan lotion or skin oils.
Test strips :( I know I need to get a test kit that’s with the liquid. I have one but I don’t think it’s the same kind as listed on the ones to buy because it was 20 bucks. I don’t use it because I can’t ever tell the difference of the color on the color chart, so I use “Dr.Tim.Wang” pool test strips .
I don’t use sunscreen in my pool because I don’t want to ruin the water and I burn too easily so I go in it around 6pm onward. And I shower and scrub the soap off before I go in the pool.
I tested my water and the chlorine is gone ( it was perfect this morning when i posted originally) and it’s been super hot and sunny but I’m assuming it’s Because I didn’t add stabilizer yet, even though it’s a stabilized chlorine puck….
the “stuff” clung to the chlorine floater and is brown.
I wish I knew what it was.
Thank you for your reply.
This is correct, you need stabilizer to protect your FC.
The recommended kits dont use color matching (except for the pH) and so are way easier to use. The paper strips are just not useful for recommending anything.
