Moved from here.
Hi Everyone,
I'm reviving this thread cause I'm having this same exact issue where multiple light colors are not available. Has anyone experienced and/or resolved this issue?
The only difference from the thread above is that all my lights are synced.
Troubleshooting steps:
Any other ideas? I've randomly been lucky to get all the colors once or twice when I've turned the lights on in the past but most of the times, I'm unable to get the violet, red, green color.
Thank You
Hi Everyone,
- iAqulink support reset all my equipment
- iAqualnik support confirmed 3 lights per each relay since I have 6 in total
- Electrician confirmed sufficient voltage
- Replaced transformer
- Issue persists whether changing colors through the iaqualink control panel linked to the pool equipment as well as through the web based iaqualink as well as the iaqualink android application.
- Changed the light manufacturer settings through the application do different brands but still can't get all colors
Thank You
