Jandy vs flopro pump does not start on schedule.
Faiz360
4
Sacramento
hello all, i have a problem with my Jandy vs flopro pump. It does not start on set automation schedule. When i check in the i aqaulink app on schedule time, it shows 0rpm and 0 watts. During troubleshooting i noticed that if i turn off the switch and turn it back on then the pump will start on schedule time bit next day again it will give same problem and i have to do this switch in off process again. So basically i am doing this manual on off duty everyday even though i have automation controller connected. Please help as this makes impossible for us to leave for a few days if we want to go out as we have to be home to do this switch on off duty once a day.
When are you checking the system status to see if the pump is running? It is only running 3 hours a day from 7pm to 10pm. You should check at least 5 minutes after start time to give the pump time to prime and spin up. Also make sure your system time is correct. Does your Aqualink have Internet access? If so, you should be able to start the pump remotely if it is not running.
Thats the problem. The iaqua link app and the automation cotroller shows that the pump is on and running. But the pump never starts even after an hour of scheduled time. Then i go and turn of the power swith wait for about a minute and turn it back on. Then the pump starts and runs the cycle for the day. Next day again same issue.
For example look at this ss. It stays like this 0 RPM and 0 Watts until i power it off and on.
