Jandy variable speed pump with aqua link
RodB
78
Pennsylvania
Hello all, so I have a variable speed pump it’s scheduled via aqua link. When I regenerate DE I want my pump to run full speed for 24 hours bypassing my schedule. Is there something simple in the app to allow an override of the schedule to accomplish that. I do t want to mess with my schedule. Also using service mode seems to run the pump at a much lower speed the needed. Maybe there’s a way to set the service mode speed of the filter pump.
Thanks in advance!
Rod
If you have an extra aux available, in the VSP setup menu you can assign that aux to one of the speeds. Then in Device Runtime you can set that aux to run for 24 hours. To use it you would manually turn that aux on in the equipment tab and it will turn off 24 hours after you turn it on.
I'm on my phone now, but can get you more detailed instructions and pictures tomorrow if you need me to.
Thanks in advance!
Rod
Please do what you get time. I’m not sure what you mean. Thanks
I like my aqua link but sometimes they miss very simple things. They should have a setting for filter pump speed setting in service mode. That way it won’t follow it mess up the programmed schedule. When I regenerate I do not want to follow my schedule because I have some hours off and some very low speeds. I’m sure there’s a way maybe I’ll call them or someone else will chime in. Thanks !
