Jandy RS4 issue. Help please
sleshnyc
2
ct
So my RS4 the lcd display went out, but the display still has backlights, and red light for the filter pump is on but the unit is not responding or sending a signal to the pool. I've had zeros issues with it until now. Is this just a pcb board replacement type thing? If so any recs on where I can source. I"m not scared to unscrew and rescrew 4 wires.
Thank you for your help.
Welcome to TFP.
The Aqualink outdoor panel does not have an LCD display.
Is your problem with the indoor All Button Control pad?
If so first check that the problem is not with the wire between the indoor control pad and the outdoor panel.
Remove the indoor control pad and take it out to the outdoor panel and connect it with a short 4 wire cable and see if it works.
Welcome to TFP.
sorry yes i was referring to the indoor controller. i will try your suggestion. any reason why it would just go? and why the panel itself has power (because the red light is on over the Pool pump, but the lcd display is dead and the controller no longer 'controls'.
If the controller is bad what are my options.
Thank you again
There are four wires. Two provide power and two provide data. A critter may have chewed the wire and broken a data wire.
Buy a new One Touch Control panel or all Button Control panel or change to iAqualink app controls.
