Hi All, new pool owner here. Over the last few days, twice my pool pump motor has overheated and stopped, which I am guessing is because of some sort of overheat protection mechanism. Once I let it cool down for a while it seems to restart. I am not sure what the issue is but looks like something is failing and I will need to address it in the very near future. My pump model is Jandy Stealth Pump, High Head, Up Rated, 2.0 HP, 230v (MODEL: SHPM2.0).
One option will be to replace the motor only. Wondering if this is something recommended and I can do it myself? In case I have to replace the entire pump, my understanding from reading lot of forum threads is to replace it with a two speed or variable speed pump to save energy. As I will be doing it myself, it will be advantageous if the replacement pump has a with very similar physical profile to keep the re-plumbing down to a minimum.
I started looking online for my options and now I am thoroughly confused. I see Jandy current SHPM2.0-2 (2 speed) as the closest option but not sure what other options (manufacturers / variable speed) are out there to give me best bang for my bucks. Therefore, wondering if you can point me to 2-3 options that will be well suited for my pool pump replacement.
