Jandy pda. Can I fix?
robl45
965
Parkland, FL
See picture
I know someone posted years back about pulling these apart and not sure if the rubber went back on or what was done. As can be seen the rubber is either gone or deteriorated at the bottom. Is there an easy way to fix asi believe new ones are insane. I would switch to Iaqualink with my phone but they don’t warranty if you buy from eBay or wherever and my luck it would be doa. Regardless fixing this would still be way cheaper
New ones are expensive, I keep mine around just to use while we are in the spa (keep my phone away from water). you could check auction sites for a broken one that could be used for parts
