Jandy JVA
Feb 14, 2015
9
Baton rouge
My Jandy JVA wasn’t coming on so I opened it
Up and full of water. I’m going to let it dry out. What are the chances it will work if I try it? Could I try to rebuild it or is it not worth it?
They can be rebuilt if you can find the rebuild kits. If the drive motor is dead, then you might just want to buy new. But you’re going to want to take it off the valve and completely take it apart all the way into the gear box. Must guess is there is a lot of rust inside there that needs to be cleaned up.
