I bought a Jandy pool heater JXI 200,000BTU.
This year go to turn on the heater and the screen is blank and machine is not firing up. So I did a little bit of troubleshooting and noticed that the 2 amp fuse after the transformer testing the transformer I had 24 V at the transformer but at the fuse was blown so I replace the fuse and power the unit back up in the fuse blow again.
I unplugged main cable into the controller board the fuse was not blown until I plugged the main cable back into the main board.
I’m thinking the control board is bad. Would this be covered under warranty considering the unit is only a year old.
Looking forward to your response.
Thank you,
HB
Thank you,
HB
