Jandy 2 hp VS ePump contolled by their JEP-R wired controller. It has terminals to connect to for remote operation (closing common and terminal #2 for Speed 2, etc.)
What I'd like to do is run on the lowest speed for circulation and temp monitoring at the heat pump, but when the heat pump starts have the pump bump up to a higher speed. I can easily do this with the remote terminals and a relay in the heat pump.
The problem is when the heat pump satisfies, and that remote relay opens the pump shuts off rather than revert back to the lower speed.
Is there a way around this?
