C cdclw Active member Feb 8, 2015 33 san diego Sep 20, 2020 #1 Holding Salinity button for 5secs is supposed to disable the beep, but doesn't. The SWG hasn't worked for some time, I add chlorine. Anyone have tricks for disabling annoying tone... permanent is fine
PoolGate Gold Supporter TFP Guide Jun 7, 2017 5,205 Damascus, MD Pool Size 29000 Surface Plaster Chlorine Salt Water Generator SWG Type Jandy Aquapure 1400 Sep 20, 2020 #2 Have you tried setting output to 0%?
J JamesW TFP Expert Mar 2, 2011 21,969 Sep 20, 2020 #3 There's a jumper on the circuit board that will disable the beeper or you can just disconnect the power wires and use wire nuts to cap them off.
C cdclw Active member Feb 8, 2015 33 san diego Sep 20, 2020 #4 JamesW said: There's a jumper on the circuit board that will disable the beeper or you can just disconnect the power wires and use wire nuts to cap them off. Click to expand... Thanks James! guess i have to find the correct jumper...or, disconnect power to the entire board? guess it doesn't matter if Im not using it.
C cdclw Active member Feb 8, 2015 33 san diego Sep 20, 2020 #5 PoolGate said: Have you tried setting output to 0%? Click to expand... well that's a great and should have been obvious idea.. will try, thanks PG
