4.1 is low.
A good cell is about 5.6 amps.
It is probably on the border of where it gives an error.
Typically, the center pin is the fault point.
You can remove the screws on the pressure plate at the pins and remove the plate to check the pin.
You can switch the cell type to 700 by cutting the jumper.
That might give you some more life.
You would have to reconnect the jumper later if you go back to a 1400 cell.
- PURE700 - 0.625 lb./24 Hr. (283 gm/24 Hr.)
- PURE1400 - 1.25 lb./24 Hr. (567 gm/24 Hr.)
Both cells use the same Power Center box. However there is a jumper on the Power Interface Board that is connected for the 1400 cell and cut for the 700 cell. The Power Center comes configured for the 1400 cell and the JL1 jumper must be cut if using the 700 cell.
www.troublefreepool.com
If you are switching from the 700 cell to the 1400 cell the JL1 jumper needs to be reconnected.
The PLC700's have a 2 prong plug system and the PLC1400's have a 3 prong plug system.
Page 17 in the
Jandy Power Center Installation Manual shows the location of the jumper.
The center prong is the most common point of failure. You can usually see evidence of a leak when you know to look for it.
