Jandry Heater - IGN Switch Jandry Filter - Breather tube
Richardya
8
New Jersey
--1--I am getting that message that my IGN switch isn't working. Heater has been this way since season opened. (New pool guy opened pool) Aside from turning off the breaker to restart it, because there doesn't seem to be and on/off button, do I need an electrician or pool guy to replace that? I am not messing with 220 volts unless its a super easy fix.
PS. Is there a way to make this heater Wifi controlable like my pump?
--2--I had to replace my cartridges because my pressure went to 20 PSI and there was barely any circulation in pool, and chlorine wasn't circulating. (I think a ton of Floc got in the cartridges because they weighed a ton compared to new ones, unless that was water.) Anyway, it fixed everything and pool is flowing and clean. I noticed this piece (See below) seemed to be cut or broken. Is this the replacement? Amazon.com
--3-- My test kits should arrive soon, I am 40% done with the PDF you have. Are there some basics I should buy so I am ready? I have the a giant pale of chlorine bars and alkaline up, so I will use those before switching to liquid chlorine.
IGN error is usually the ignitor, which you should be able to replace yourself. It is a consumable.
That plastic hose sticking up on your filter is supposed to have a small metal filter on it. Clean it out it should be able to have flow through it.
You can control your heater with automation like Aqualink.
