I have had the pool for 3 years now, and it's been ok for the most part. It is 15 years old, around 30,000 gallons. It wasn't covered for the winter, and it was really bad with algae and solids. So I had the bright idea to drain it and start fresh. I also wanted to drain so I could clean some of the white build-up from the vinyl. I had drained enough to fully expose the shallow end, but then realized I was in over my head. Started seeing some things on-line about the risks of draining and possibility of collapse. So I didn't drain it all the way. But the weight of the water remaining in the deep end has put a strain on the liner, causing it to start pulling away from the shallow end. It hasn't come out of the fastener, but there is no slack to push it back against the wall. I just wanted to get some ideas of how to proceed. I don't see how I can get the liner straightened back out without completely draining.
