Hey TFP -
On the side wall of my inground pool, there is a place with a fitting where I screw in the hose to connect the pool cleaner. A couple days ago, I noticed the cleaner hose had disconnected and was just floating in the pool. I have tried to reconnect several times, but as soon as the cleaner turns on, the force of the water is pushing enough to disconnect the cleaner hose connection. I should note, I am quite familiar with connecting/disconnecting the cleaner, so this is a brand new issue.
I've used my finger and felt inside the plastic fitting piece on the pool wall. Normally there is a notch to catch on the cleaner hose, but that notch is barely there and feels like it's worn down. Is this something I can just get from my local PAP store and replace myself or do I have to call professionals? Pool is 5.5 years old.
