Hello, I am have an issue with 2 pools we service. Both pool have the same pump and same suction side cleaner. In both cases once the cleaner or our vac line is connected either the skimmer or vac port the pumps lose flow. We get about 25 percent of the pot full when connected. With the vacs removed the pot is full. Pump is the superflo vsf. We have tried various speeds. We have tried bypassing the filter to rule it out. All with no increase is flow. There is not enough flow to efficiently vac or run the MX8. I am leaning toward a crack in the lines or a failed joint. Works fine when under normal pressure but once pressure is increased with a vac hose it allows air….? Both a 2” lines. Both are brand new pools so this is odd. Any ideas?
