ISSUE in Effects of adding !
wireform
In The Industry
Aug 15, 2017
7,896
Spring Valley, NY
Noticed this before but keep forgetting to check when I switch between pools that have different cell types. For instance, if I was checking a pool/customer by the "effects of adding" in the SWCG category I find that the cell type is different then the one I have in the settings, so I proceed to correct it and find the % or time I need to hit the FC and thats perfect. Now if I'm checking another pool/customer in their pool and I go to check the same category "SWCG" calculations I find the cell type to be the one I had last changed for the pool just before this. Now it could be 5 minutes later or 24 hours later and the same problem occurs. I find myself not excepting the answer and checking it again as I always forget to check what cell I'm calculating for. This happened again tonight as the answer didn't seem quite possible only for me to then realize the the cell type switched.
