- Mar 5, 2020
- 3,072
- Plaster
- Astral Viron V35
Don't forget to adjust your target FC with rising CYA. If CYA is 50 now and SWG still off, then you want to target FC 6-8ppm and not have it fall below 4ppm. As soon as you drop below 4ppm you risk algae which you want to avoid especially with fresh plaster.
Is your chlorine fresh? Have you verified by testing about 30min after adding chlorine with the pump running, that the addition increased your FC by the expected amount?
