Is this damage ok on a new Dolphine Active X6
n00bling
Active member
Sep 10, 2021
27
Sydney
I purchased a new Dolphine Active X6 recently and noticed the back tire was a bit damaged. I'm not sure if this is ok or not but wanted to check before I use it as I paid $2.5k AUD for it.
Welcome to TFP :)
That is perfectly fine and once you put it in the water it will fill with water and look perfect.. That is a wear item so every couple months have a look at it again as it wears down over time.. Mine looked way worse than that, in the US they started putting in a warning label about it :)
Yup - what he said 👆🏻
It’s from being shipped & sitting in the box. Not damage persay just mushed. This is the reason you should also store it on its side or on the caddy when it’s not in the pool.
Reactions: BowserB and borjis
