Hi all
Now on day 4 of a SLAM due to OCLT results of over 1ppm (initially overnight loss was around 7ppm but now around 3 / 4.5pom).
Actually started the SLAM on Mon & Tue last week but then ran out of liquid chlorine and had to wait a couple of days for more to be delivered (in the U.K. it’s not so easy to get hold of in a hurry!) so I’m officially counting Friday as the start of the SLAM.
CC is generally 0 / 0.5ppm and water appears crystal clear, so OCLT is the only thing letting it down.
However, I’ve noticed a black line keeps forming in the same spot inside my Aquagenie Skimmer (which was already pretty dirty and I’m trying to scrub it down).
It’s maybe 2inches or so in length and pretty thin. It smears and wipes away really easily but usually is back again several hours later.
Not sure if this is algae or just some other dirt which collected in that spot after scrubbing (as mentioned I’m scrubbing inside the skimmer fairly frequently at the moment to try and clean it up, I don't think the previous owner had ever cleaned it).
I do also get what feels like quite a large number of bugs in the pool (flys, spiders etc…). Of those that I don’t get with the net, some sink to the bottom but a lot of them are collected in the skimmer. Of those that end up in the skimmer, a lot are caught in the basket but a lot also float around the surface, so not sure if that’s a possible cause of the line too?
