New dude, I just did the same thing.
www.troublefreepool.com
The winterizing rubber plug got sucked into the pipe nearest the filter pump because this year I didn't take the gizmos off first. The pipe has a 90 degree bend right at the end so I can't see down it. You say a shop vac sucked it out? There was enough pressure to get it out? Any advice?? Help!! Do I leave the gizmos in while trying to shop vac it out?
Is there an order to removing plugs and gizmo when opening?
I asked for help with opening last year but I ended up using a pool company so I apologize if I'm asking the same question. I don't think I can screw up anything too badly with opening vs. closing but want to be sure I'm doing it right. I had a pool company close my pool and they put plugs...
