Summer #2 with our AGP, and thanks to TFP I opened to a perfectly clear and beautiful pool. I did however find a minor issue, where the skimmer has a split in it, resulting in a minor leak (literally a drip per minute or so).
Two questions:
1) Is this repairable, or am I needing to replace the skimmer? My feeling is that this will keep until fall drain, unless it gets significantly worse...
2) What did I do wrong? I assume this is a result of a winterizing failure, but I believe I followed the process well. Pool was drained to ~9" below the bottom of the skimmer, all lines were drained, blown out, gizmo was installed, pool was covered, top of skimmer was covered with plastic so no snow could get in. The cover was new and water-tight, as I had zero infiltration from what I could tell. Even with snow melt, water level was about the same as where it ended last year, ~9" below skimmer bottom when I removed the cover.
Thanks in advance for your thoughts!
Two questions:
