Hi all,
I finally got my filter and everything running and I'm not sure if the pump is cavitating due to my setup, or if I still have a leak somewhere, or, if it's just pulling air from the skimmer.
I'm using a Hayward 1.5HP 2 speed Matrix pump.
Here's a video I took yesterday. :
The pump in high speed definitely sounds like there's air in it but I don't see much going in, though there are some very small bubbles but barely.
In low speed it sounds beautiful.
Is a single skimmer with a 1.5" hose not enough for a 1.5HP pump? Is it likely cavitating or do I just have an air leak somewhere?
My plans were to use high speed for vacuuming, but if it's cavitating without a 30' hose on it I'd imagine it's going to be much worse with a vacuum.
If I restrict the return more it quiets right down and I'm running a 3/4" eyeball.
