Hi.
We just moved into a new home with a 16’x32’ oval above ground pool. It is decked in. We have to replace the liner, and I’m a little concerned.
1) the track the liner attached to appears to be poking the liner. This is at the joints, they are not flush. Is this fixable or does the entire track need to be replaced?
2) more concerning, you can see I the pics the imprint of the uprights through the liner. I assume this is not usual, but is it fixable? Once drained, will I be able to just adjust the uprights and push backwards so the liner will not be push up against the uprights? You can see that the liner is wavy now where the posts are.
