Is My Board Fried?
Jun 30, 2013
15
Plano, TX
Hello - Strong thunderstorms came through here late Monday night. On Tuesday morning, my Aqua Rite pad (inside the house) was blank. No lights on at the AquaLink control panel. I flipped the breakers off and then back on, and the panel lights did not come on. Shortly thereafter, the main pump turned on by itself, and everything seemed to be working fine, including the pad inside the house. On Wednesday, the same thing happened - blank pad and no lights in the morning, then the equipment started up on its own and progressed through the progammed cycle. Yesterday, everything stayed dark and nothing turned on. This morning, everything is dark. I've tried turning the breakers off and on, and replacing the back up battery. Still no response at the panel. Through all of this, the lights / display on the salt system panel have remained lit. This seems like it is related to the electronics - is there a way for me to check the board / electronics on my own? I usually can repair / replace smaller or less complex things on my own, but usually get into trouble when I try more complex repairs. Is a job for an electrician or a pool repair company? thanks!
