I got a pool robot and now I am spoiled by not having to vacuum. My next issue is skimming. It seems like my pool always has small fine debris and bugs on the surface. Manually skimming them with a net is a chore I would rather avoid. Are you all skimming manually every day or am I doing something wrong? The skimmer net and pole I have is kind of heavy so it is annoying to do.
Also, I'm not sure my skimmer is working correctly. It doesn't seem like the surface water is circulating, the bugs/debris just stay in the same general area. I do have a flap for the skimmer basket and it defintiely looks like there is suction. Water is clear so I assume the water is being circulated. It just seems like the surface is not. I was thinking, maybe I am keeping the water level too high, but I've kept it low for a few days and still no results. I use a skimmer sock and I do see some fine debris daily. so something is working. Perhaps just the amount of bugs/fine debris coming in is far greater than the amount being picked up by skimmer. Is manual skimming the answer or am I missing something?
