Alright, sort of a two part question here. I have searched this great site and read lots of articles, but still keep going back and forth on the type of pool to have installed.
This is our first pool build project and the amount of options is pretty overwhelming. We also have a ton of pool builders in the area and deciding who to use has proven more complicated than i would have imagined. We have close to four feet of elevation drop from the up-hill side of the project site to the back of the pool project (fence line). This means either one (up hill side) or possibly two retaining walls would be needed for a fiberglass or vinyl liner pool which plays into the overall cost for those two options. The Gunite pool contractor said he can deal with some of the elevation by using the pool wall as retaining wall and thus come in closer to a comparable project cost vs fiberglass and vinyl liner. The first full project bid came back from the Gunite builder and I have included the details below. The Gunite pricing and project is going to really push the budget I had set, as what is listed below is just above our budget (about $3K over) but i still need to put in landscaping (minimal) around the pool, reinstall and add some additional aluminum fencing and take out two large trees. My estimate for those items is probably another $6K-10K.
The Gunite pool would definitely be the nicer pool aesthetically vs fiberglass and vinyl in terms of his design with the Raised Bond Beam natural stone wall with two waterfalls and fountains on the sun ledge and travertine coping. Just not sure if it is worth stretching the budget by $12K-$15K (maybe more...) for some of these things we didn't even consider originally. I was originally sold on a fiberglass pool due to installation and maintenance over the next 20 years we plan to be in house. Now with the elevation change and the fact that one side of the fiberglass pool would basically start 4 feet out of the ground before they started work with back fill and building up the berm and walls to pour concrete, the fiberglass installer made me nervous with that product in our space. (He didn't seem as confident as one would hope in figuring out how to make it work, and all that company does i put in fiberglass pools.)
To complicate things, yesterday I came across another local pool builder in our area that does the Aquabright finish. After looking into this and talking with him yesterday I am very intrigued by that product and build process. He is coming out Tuesday to look at our space and work on a bid. For the size of pool we are planning (around 18' x 36' or 38') the cost looks comparable to fiberglass in our area.
Sorry for all the rambling and random thoughts. Back to my first question...in the pool bid below for the Gunite Pool...do you see anything missing or not needed that could impact the project cost? Looking for areas that may be an add on later as it is missing from the original bid as I would like to have those items on the table as we work to make a decision and get on the build schedule sooner than later.
Thanks for this great site and the collective knowledge within this group!
GUNITE POOL PROPOSAL
PLANNING
DESIGN AND PLANS INCLUDED
PERMITS AND FEES INCLUDED
SURVEY COST IS NOT INCLUDED ($500-$800.00 COST)
POOL
18X36 GUNITE POOL SHELL
FULL REBAR CAGE ON 8” CENTERS-LIFETIME WARRANTY ON SHELL
PEBBLE TEC PLASTER INCLUDED
TILE AROUND SCUMLINE (IN STOCK TILE)
TILE WATERSPOTTERS ON BENCHS/SUNDLEGE INCLUDED*
3’4 SHALLOW END DEPTH
6’ DEEP END DEPTH
SUNLEDGE OF CHOICE WITH (2) FOUNTAINS INCLUDED*
CUSTOM STEPS OF CHOICE
DECKING
TRAVERTINE OR NATURAL STONE COPING INCLUDED*
400 SQFT CONCRETE DECK INCLUDED
INCLUDES ALL ROCK BACK FILL MATERIAL
PLUMBING
2 SKIMMERS
1 SET OF MAIN DRAINS
4 RETURNS
2” SCHUDLE 40 PIPE ON SUCTIONS SIDE(EACH LINE IS DEDICATED)
2” SCHUDLE 40 PIPE ON RETURN SIDE (2 LINES PER FEED)
PENTAIR 3HP INTELLIFLO VARIABLE SPEED PUMP
PENTAIR SAND FILTER WITH CLEAR PRO TEC.
PENTAIR CLEANING EQUIPMENT
IONIZER FOR METAL IN POOL
2 CHECK VALVES
ALL PENTAIR BALL VALVES
CONCRETE FILTER PAD
SERVICE
CLOSING OF POOL 2018 OPENING OF POOL 2019
CHEMICALS INCLUDED FOR 2018
3 YEAR WARRANTY PARTS AND LABOR ON ALL EQUIPMENT
POOL OPTIONS:
-PENTAIR CONTROL SYSTEM WITH IC 40 SALT WATER GENERATOR (Included)
-3 PENTAIR GLO-BRITE LED LIGHTS COLOR CHANGING W/ TRANS) (Included)
-WINTER SAFETY COVER (Included in total project cost)
RAISED BOND BEAM ON POOL:
-APPROXIMATELY 18’ LONG 18” RAISED WALL
-NATURAL STONE RAISED WALL
-(2) 2’ SHEER DECENT WATERFALLS
-NATURAL STONE CAPPING INCLUDED TO MATCH POOL
EXPOSED WALL ON BACK SIDE OF POOL WILL BE BARE CONCRETE:
-APX. 80 SQ.FT. OF EXPOSED POOL WALL THAT COULD BE EITHER PLASTER FINISH OR NATURAL STONE FOR FINISHED SURFACE
FOR PRICE INCLUDED ITS BARE CONCRETE (LIKE FOUNDATION)
-APX.36 FT OF EXPOSED POOL WALL (ON BACKSIDE)
-USE BACK SIDE OF POOL AS RETAINING WALL
- TIE A DOUBLE CAGE OF STEEL ON BACK POOL WALL
PRICES BELOW WOULD BE ADDITIONAL TO CREATE FINISHED LOOK FROM BACKSIDE
PLASTER @ $15.00 SQ.FT. X APX. 80 SQFT = $1,200.00
STONE @ $35.00 SQ.FT. X APX. 80 SQFT= $2,800.00
PROPOSED UPPER RETAINING WALL
APX. 30 FT OF 20” TALL RETAINING WALL BLOCK TO CREATE ELEVATION CHANGE
-35FT LONG 24” TALL RETAINING WALL (COLOR OF CHOICE).
-PRICING INCLUDED ALL LABOR AND MATERIAL
(NOT 100% SURE WE WILL NEED THIS)
NATURAL STONE STAIRS (From Pool area to drive way)
-3’ WIDE TO 5’ WIDE
-ROSETTA IRREGULAR PRE CAST STEPS
-COLOR OF CHOICE
-ROCK COMPACTION INCLUDED
-FLAGSTONE STEPPERS TO DRIVEWAY WHEN REACH TOP GRADE
-ALL LABOR AND MATERIAL INCLUDED
LANDSCAPING:
RE-PLACE/RE-RUN NEW DRAIN TILES FROM HOUSE
CLEAN UP ALL ROCK/CONCRETE DEBRIS
RETURING YARD BACK TO GRADE SEED AND STRAW
CONCRETE DECK PRICING:
BROOM FINISHED CONCRETE @ 7.50 SQ.FT.
SGM COATING @ 15.50 SQ.FT.
STAMPED CONCRETE @ 12.50 SQ.FT.
TRAVERTINE DECKING @ 26.00 SQFT
NATURAL STONE OR TRAVERTINE COPING INCLUDED
NEW DECKING
600 SQFT @ $7.50 OF BROOM FINISH CONCRETE
400 SQFT INCLUDED IN BASE PRICE
PLUS STONE COPING
TOTAL OUTSIDE NEW CONCRETE WILL BE 1150 SQFT OF DECKING
FENCING:
REMOVAL OF FENCE INCLUDED
-REINSTALLATION WILL BE ADDITIONAL COST
ELETRICAL
POOL AND WIRING INCLUDING:
-60 AMP FEEDER TO POOL PANEL
-POOL PUMP WIRING
-POOL HEATER WIRING
-POOL LIGHT WIRING
-GROUND AND BONDING POOL EQUIPMENT
PLANNING
POOL
6’ DEEP END DEPTH
DECKING
PLUMBING
2 SKIMMERS
4 RETURNS
2 CHECK VALVES
CONCRETE FILTER PAD
SERVICE
POOL OPTIONS:
-3’ WIDE TO 5’ WIDE
-COLOR OF CHOICE
LANDSCAPING:
NEW DECKING
PLUS STONE COPING
FENCING:
ELETRICAL
-POOL PUMP WIRING
-POOL HEATER WIRING
-POOL LIGHT WIRING
