Is a bypass manifold necessary???
suzook
570
Senoia, GA
I'm getting an autopilot system, and my old one had the manifold with swg cell on my old pool. I'm thinking it's unnecessary, as I rarely run the vs pump at high speed. Only time I do is to backwash, or pump out too much water. Thoughts???
What model pump will you be using?
Model filter?
Your 1.85HP pump is not going to have enough flow to require a bypass on your Autopilot SWG.
Eventually, but I always put a bypass on that. I don't know why that's relevant.
It is relevant because a heater adds resistance to your plumbing and will further constrain your pumps maximum flow rate.
