- Aug 22, 2017
- 2,996
- Plaster
- Hayward Aqua Rite (T-15)
So my irrigation well stopped working. It looks like both the bladder and pump are done. The pump is currently a Pentair Sta Right 1hp pump and the bladder is also a Pentair Pro-Source. When they cut the bladder off to drain it (it was full of water) a very slight amount of sand came out. Less than a hand full. The irrigation guy said that could be what blew out the pump and suggested that I have my well inspected or redone. Is a little bit of sand normal or do I really need to have the well checked out?
They also want $2300 to replace the pump and bladder and use a 1.5hp Goulds pump instead of the Pentair pump. Not sure if that is reasonable or not?
Do I bother to try to have the Pentair repaired? Should I insist on another Sta right or the Goulds a good pump?
The well and the whole installation was done in 2014, and the well was dug to about 130 ft deep.
Any advice?
Any advice?
