It's not linear it's logarithmic so we round up to the next 10. 41 to 49 is 50 (etc etc). SLAM target is 20 FC.came up to about 45ppm
Well it takes FC to make CC. If the FC got depleted quickly, you wouldn't see any now.Low FC could maybe be expected, but no CC at all?
Better safe than sorry. The test is free and quick so there's no drawbacks.still a good idea to follow Newdude's advice to really rule out ammonia.
Adding 3 gallons now and will test in 30 minutesAdd to 10 ppm. Test 30 mins later. If you have most of it left, you're good. If you don't, it's ammonia.
FC says 11ppm after 30 minutes. So now I'll bring up to 20ppm and test again in an hourAdding 3 gallons now and will test in 30 minutes
pH was at 7.5 this morning and I added a bit of acid before I added the initial 5 gallons. Sun is off the water now so hopefully it stabilizes. Going to add a few more gallons now.Keep the course.
In the early stages of a SLAM you have to top up FC often. The elevated chlorine level helps to kill algae fast, but that also implies that chlorine is being used up fast in the process. The higher the FC, the faster the algae killing, and the faster the chlorine loss. Plus all the losses to UV at elevated FC levels.
Did you make sure to lower pH to 7.2 (or at least making sure it's below 7.5) before going to SLAM-FC, as described in the SLAM article? One of the benefits is that it reduces FC-loss to UV. pH is not a very significant factor for UV-loss at target FC-levels, but quite noticeable at SLAM-levels.
Have you tested at all to verify you are hitting the target 15 mins after adding ? It could be weak / degraded chlorine making it seem like it fell when it never got there in the first place.I can't even get to SLAM level for more than 30 minutes since its burning off/getting used up so quickly.
