Fairly experienced Intex owner. Owned Intex pools for the 13 years but the last one I put up was 9 years ago. It was the old style white metal frame and help up well, staying up year round. The rust had got to the point that I took it down and bought the 22x52.
After waiting 4 weeks to get someone to clear and level the ground, finally started the install on Saturday morning. The setup went fairly well and I stopped filling Saturday night when it was just below suction fittings. It rained hard Saturday night and Sunday morning I got up and started the water. Started the pump once the water was high enough and added 6 bags of salt. I need 8 bags, so I left to go get 2 more bags and when I came back the water was brown. After some calls, there was a water line break Saturday night and I was unaware, so my pool is full of iron. Started on the iron clean up and making progress (clarifier, aeration, sand filter) doing a slow clean up. Looks green in the pics, but its definitely iron related.
One thing about the new Intex pools, they no longer come with a rope that goes around the bottom of the legs, so I assumed I didn't need to worry about that. Go to work Monday, storms roll through and I come home to see a leg has slipped off the footing. Looking at it, the bottom kicked out a little and came off the footing and down into the ground about 1 -2 inches.
I'm not worried about it continuing to sink, just wonder how much stress is on that section right now. Pretty sure the only fix is to drain the pool - is there some sort of "trick" to fix it without draining? Also, should I get something to go around the bottom of the supports, and if so, any suggestions on what is best. I know the Intex rope from my last pool basically dissolved after a few years, but the post were set and never moved.
View attachment 62966View attachment 62967
