I have one of the original 7k gallon intex salt water generators on the intex 18x48" pool, along with the 1.5hp matrix pump.
I've dumped probably 5 or 6 bags of salt into the pool at this point, because the indicator light kept saying low salt (not sure why).
My meter was showing 5000 ppm, wayyy higher than it should be, i think 3k normally, unless the meter is off.
On average in the last week i was generally around 2 FC for the tests, then today, zero.
The pool is an avg of 86F each day, i had used stabilizer to level things out about a month ago. The pump runs from about 9am till 630pm daily and the chlorinator is set to 10 hours.
Any tips to solve this one without trying to replace the unit?
I was thinking of getting this 15,000 gallon model, its nearly the same price as the newer model 7k unit, any reason to not do that if the old is in fact defective?
EDIT: i guess the salt indicator issue is common and a problem with these units, maybe not the 15k model, unsure. Or perhaps i need to look to another model.
Thanks in advance
Amazon.com
www.amazon.com
Thanks in advance
