Intex Pure Spa Bubble - Filter Suction Direction
ms2067
1
Switzerland
Hello everyone,
I'm not sure in which direction the water flow should be. In our Intex Pure Spa Bubble, the filter cartridge is connected at the top (highlighted in blue in the picture).
When the pump is running, the water is drawn in from the bottom (highlighted in red in the picture) and pumped through the filter into the pool at the top. Shouldn't it be the other way around? Meaning, the water should be drawn through the filter into the pump?
Thank you for your help.
