I have spent 3+ weeks getting our pool site cleared and leveled, and on this past Saturday we did the final inspection (small rock check, put down thin layer of sand, then put down 2 tarps). After everything looked good, we assembled our pool, and then did a 2-3 inch fill to check level. After a slight adjustment on the low side (using half-buried pavers -- NOTHING touching the liner at all), we started the actual "go live" water fill. After the water level rose to about 8-9 inches, I thought I would walk around the pool and check vertical level on the legs. When I got to the back of the pool (which would be considered the low side IF there is a low side), I saw that the top tarp was a bit wrinkled under that leg. So when I raised the leg a bit to pull it out flat, I noticed a tiny bit of water trickling out from under the liner. NOT GOOD (I thought to myself). I pushed up the liner with both hands, and noticed a small puddle of water on the tarp. I took a towel, dried the area, and did not see any signs of any leak. After another hour or two, I went back and checked that area again. Small puddle had returned. So definitely water coming from somewhere. At that point, I shut off the water filling until I could figure out what to do. I checked all other areas around the edge of pool, and no signs of any water -- just this one 2 foot area in the back. I tried the blue food coloring trick in that general area -- nothing. At this point, it was almost dark outside, so I stopped for the night. This morning, I walked out to check it, and I have maybe 1 cup (at most) of water puddled around the back paver (which is half-buried in the ground). There has been no rain or any other water source, so there MUST be a very small leak somewhere in the liner. Since this back area MIGHT be 1-2 inches lower, then gravity may be in play here and the leak COULD theoretically be further up towards the higher side of the pool (and just slow-trickling down to what I am seeing). How in the world do I find this leak? Even if I drained it and disassembled it, I'm not sure how you find a leak like this. While not a perfect option, is losing 1 cup of water a day an acceptable leak risk (that I can live with for this summer), or is it guaranteed to get worse once I completely fill the pool? Obviously, I cannot afford to keep spending weeks on getting this pool up and running -- school for the kids starts back in August!
I investigated the Intex liner 1-yr warranty options (since this is new pool), but it looks like Intex requires you to ship the liner (prepaid and insured) to them for them to validate that it is a manufacturing defect. That shipping alone would probably cost a lot (not to mention the pain of drying and re-packing that liner into a box!), and then what happens if they say "sorry, you caused this leak"? Do I then have to pay shipping AGAIN to get my liner back? Doesn't sound like a great option on a $300 pool...
Would appreciate ANY ideas, advice, or input on this! I've tried to self-educate as much as possible (youtube, forums, etc.), but I am stumped at this point (not to mention the VERY disappointed children!). Thanks all!
