Hi all, first post here. I've been searching and reading all of the fantastic advice on this site. Thank you for that. We are about to install an Intex 18' x 52" pool. I have the ground dug out and leveled. My plan was to put a layer of sand down and set the legs on pavers. Intex specifically says to not use sand, but it appears that a lot of people still do. I set the pavers down into position just to see what they looked like. They are all almost perfectly level all the way around already. What my plan was to do is to have sand delivered and put enough sand down to match the level of the pavers. So since the pavers are 1.7" thick, that would be 1.7" of sand. That way I do not have to dig out 18 square holes and start from scratch trying to level each paver and the level all 18 together since they are already level. Do you see anything wrong with adding the 1.7" of sand to bring the level up to the top of the pavers? That would be the same thing as setting the pavers in holes level with the ground.
