Intex liner question
5MARC
0
Sep 19, 2016
14
Central Ohio
I had a 26’ Intex ultra frame pool. It developed some leaks, as they do & it was not repairable. I could not find a 26’ AGP liner to put inside it, so I set out to find a new Intex liner to get my pool back up & running. I have had little to no luck finding a replacement, but have come across a summer waves elite pool liner, in the same size & depth as the Intex. Does anyone know if they are similar enough that I could use my existing frame from the Intex pool in the liner for the summer waves elite?? Pool season is creeping up on us & I’m hoping to be back up & running when the weather here allows.
Thanks for all your help & input!!!
I'm not certain if it would work, but you could look at the specifications for the summer waves and compare it to your current pool.
Are the support legs equal distances apart? Are there the same number of support legs/beams? Does your model of intex use the round or oval horizontal beams? (Not sure if they have a difference in size enough to matter)
I would verify if the summer waves liner you're looking at does or doesn't have a pre cut out for their skimmer/filter. My smaller (16ft) summer waves does have a circle cut out of the liner for the skimmer/filter combo.
