I posted in another thread about cleaning this thing up but now a new topic vastly different, so new thread.
Got a new to me 4 person Intex PureSpa. Tub inflates and holds, holds water, have all the parts. Started with a E90 error and fixed that with a new impeller. Then started with E96 which is a general fault.
Unplugged and let sit for a few hours. I also did my best to burp the system. It started up and I ran the filter and bubbles. It ran great for a few minutes and I added 2 teaspoons of Ahhclean. I let it run after that while I watched. After about 20 minutes, the E96 came back on. I got the E96 with the filter attached and not.
My research has shown that it is air or an electrical problem. My GFCI plug is plugged into a timer box that I have my pool on and from there to a GFCI outlet on a 20 Amp breaker. On the same breaker is a 110v mini split system. I have had no issues running my 1.5HP pool pump hour on, hour off 24 hours a day while the mini-split is running.
I am wondering if I am getting interference with both GFCIs. I took the pump inside and plugged it into the wall. It is turned on but is not heating, filtering or blowing air. I can say that I inflated the lid and tub using the pump plugged into the same inside outlet with no problems.
So.... should I just run it to a non-gfci outlet? Replace the cord? Missing something?
Thanks
Thanks
