Hi all, I have an Intex 18’x52” ultra frame pool with 5e above listed pump. It’s only just starting it’s 3rd year, and the pump motor has failed. I replaced bearings, and within 30min, went from quiet to noisy, to not turning. My thoughts when I had the motor apart, was that the windings must heat up, as the inner surface of the outer windings (not sure of exact teams) was all scoured up. I think these must heat up/rub/wear and eventually freezes up.
Is is there a way to save the sand filter and salt water generator portion and add a new pump? I may only have the pool one or 2 more summers, kids are getting out of the pool phase. Don’t want to drop hundreds to keep it going, but would still like to use the pool this year. Any suggestions? Any way to wire up a separate pump, but still use existing swg and filter?
thanks for any info, direction.
