Hi All and happy 2024!
I went trough with my plan of putting Intex XTR into a concrete shell.
It's not possible to put legs for the short sides - not enough space between the liner and walls.
Should I add some support for these short sides?
My thinking was that the short sides are so close to the walls that all the side weight will be resting on the concrete walls.
I'm not sure about any downward pressure for the short pipes - the liner stretches at the bottom but how much will it pull the pipes down.
It's a little bit problematic to attach them to anything but I thought about couple of options:
1. Shorten the legs and make them parallel to the walls - they would have to be cut at the bottom which is not ideal (mostly because of rust). I wanted to keep these legs as spare. I could place a wooden plank and rest these cut legs on it. They would be probably felt through the liner because they will be directly between the liner and the concrete wall.
2. Put a wooden plank like 2x6 directly under and parallel to the edge so that it can rest on it for additional support. Fairly easy to do.
3. Use some kind of clamps here and there but the leg holes in the liner are not well shaped for that.
The legs are on both long sides.
WDYT?
Also, how bad of an idea is to test-fill it with sea water?
I've got a pump, it would much faster and cheaper.
Here it would cost me probably $600 to fill it full with tap water and would be very slow.
I'm planning to hard plumb it with pumps placed in that small building.
That round thing on the first photo is a swim jet (dedicated pump) that I plan to install through the liner, plus 2 skimmers (another dedicated pump).
Skimmers line will also go through solar heating mats (until I can get PV panels and a heat pump) and through a spillway on one of the short edges.
Thanks!
WDYT?
Thanks!
