Intex 2100 sand filter leak when off
ladman
May 25, 2016
16
Murrieta, CA.
System is up and working great though I still need to run water test. I have my sand filter on the timer function as well as the salt water setup. I noticed when the pump is off the sand filter leaks from the top where the selector lever is (large hand lever for filter, backwashng, etc..). Defective unit? No leaks when the pump is on. Thanks.
Just a suggestion. ... there are several gaskets that allow your multiport lever to seal... a couple are rubber and i think 1 or 2 of them are made of nylon and act as a ware washer when turning the lever.
The 2 important ones are on the stem of the lever housing... they stop the water from bubbling up from your filter when you push the lever down.
Is it an intex filter or another brand.. also... can you tell us what the pressure gauge says when your power is on.
Sent from my SM-G920I using Tapatalk
