- Mar 30, 2018
- 149
- Plaster
- CircuPool RJ-60 Plus
Good point on the 90s, I actually did that when installing the new pump. I see they offer this vertical kit as well.The cell can orient either way but the flow switch needs to be horizontal or have 'up flow'. If you mount it downward, gravity will close the switch when it fails. It won't be for some time, probably a long time, but it's a cheapo 19 cent moving part and will fail.
Don't be constricted by what you see. You can add pipe any direction from A to B to accomplish the goal. A few 90s won't make any appreciable change to flow.
